I have a problem with the Rankx all stores & RKS column.
I want it to show the ranking of a given store within all RKS.
To sum up: the Rankx all stores column shows a dynamic ranking depending on which country and RKS you choose - it works properly.
The Rankx all stores & RKS column should show a dynamic ranking depending on which country you choose, but it should not work with the RKS filter - it should show a total ranking in all RKS.
Code column rankx all stores & RKS:
Rankx all stores & RKS = RANKX(
ALL(DimLocalization[RKS];DimLocalization[StoreID]);
CALCULATE(SUM(FactSales[Revenue_Net]))
Unfortunately, I have an exposed cube and can’t create columns
