Query editor test string if numeric
Hi - I am trying to transform some employee id data. The employee id values are text (alpha-numeric). Generally speaking, FTE’s have a six digit number. Contractors have a number preceded by the letters CON. There are occasional exceptions to this rule of thumb. See the table in my sample data spreadsheet.
What I am trying to do is transform the values which are highlighted in yellow in column A of my attached spreadsheet to the values highlighted in green, and leave all other values untouched.
Here’s the challenge: Some FTE employee id’s are less than 100000, and in this case they show up as a value with less than six digits. I am pretty sure I can use the text.padstart function to convert, for example, a four digit employee id such as 4212 to 004212. I think I can create an if then else statement that will measure the length of the employee id value and then I can determine how many zeros to prepend.
However, here’s where an exception comes into play. We have an employee id that is four alpha characters. I don’t want to prepend any zeros to this particular value. I have tried to find a function that checks to see if the first character in a string is numeric or not, which I think I could use to then ignore that row and move on to the next row, but I haven’t been able to find a function to do this, and I’m not sure how I can take existing functions to accomplish the same thing.
Any suggestions on how to accomplish this will be much appreciated.
Thanks!
Trey
Query Editor Test String Numeric Data.xlsx (11.8 KB)
Hi @trey.cook,
Paste this code into a new blank query.
let
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("dcsxC8IwEIbh/5K5hYuR5DJaCSJCCiXgEIJoB6eCUPX3e5cL3cySl4f7clbHMaZzPIWYbtdxuoSpN71V3R8vXVafFfH7eN/paEt2Whjr9rKtxbo+X/MyE7Zg00BPk7Voa++9jDnYhjCkA5H8LN6hRRKQYNppUwVqsLTVNtLO1wPgYEAZAFCU8gM=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Employee Number" = _t, #"Updated Employee Number" = _t]),
    UpdateEmpNum = Table.AddColumn(Source, "Result", each if List.Contains( {"0".."9"}, Text.Start([Employee Number], 1))= true then Text.PadStart([Employee Number], 6, "0") else [Employee Number])
in
    UpdateEmpNum
I hope this is helpful.
This is perfect and brilliant, Melissa. Thanks so much for taking the time to show me what to do.
Best Regards,
Trey
