PowerBI Direct Share enable
There was a new upgrade last month which changed the way to share reports directly. Now when you click share, the popup comes up to send an email to different users and roles. see attached. what is workaround this new feature? pic_pbi
i want to still send report directly like before.
thanks
if you click on the > symbol, you will get additional options:
Hi @lizbethl4@, did the response provided by @Heather help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Thank you . Worked perfectly
