I have facing a issue from last two or three day my power bi data refresh fail with the below msg
I am not restarting it .
May i know anyone from you face this type of thing and how you fixed it.
Thanks,
Anurag
Thanks,
Anurag
Hi @Anurag - Not sure what the issue if Gateway is not restarting. Is it installed on a Virtual Machine/Server or some local laptop. If laptop, then there may be some updates running that may be restarting it.
Can also check below link, it contains details on all Gateway Issues and Troubleshoot/Fix needed.
If still not resolved, then raise a Support ticket with Power BI and check if they can help.
Ankit J
Thank you so much for that detailed answer @ankit
We hope this helped you @Anurag
Hi @Anurag, we’ve noticed that no response has been received from you since Oct 7. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
