Please help me do I have any visuals like below in Custom Power BI
I am looking for visuals the same as attached. anyone help me
Line
Hi @putturps,
Have you already looked at the Custom Visuals available in PowerBI Desktop?.
Insert > More visuals > From AppSource
Yes, but didn’t find any with exact match
Anyone has any input or suggestion on this visuals please?
I would suggest if they aren’t in the Appsource, they just aren’t available at this stage. That’s the only location to find custom visuals for Power BI.
Hi @putturps, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
Appsource would be the only place to find custom visuals. Unless some other companies do third party visuals like Zebra for example but i still think they post it on AppSource as well,
Are these examples i suppose from non Power BI files for sure.
