Need this very urgent I would highly appreciate your help in this regard,
Req1:
I have made the measures for each category of the line Items
Line Items are ( Individuals, Business & Industry, Membership & Subscription, etc)
and then I made Avg of all the Licensee Type.
I want the Cards to give me percentages till Grantee_Name and should not go beyond that i.e. line items as the line items are giving me the incorrect result or I am OK if the Line Item can also be fixed
If i am confusing i can explain over screen Share mode also.
Req2:
I want to make Groups based on their revenue and I want to put these groups into slicers where I can Change the Groupss in the Slicer and Data should filter based on the Slicer Data .
Thanks for posting your question. Your requirements are a bit confusing but let’s try to work out exactly by taking baby steps. First of all, you feel that when you select Line inside the Guarantee_Name, it gives wrong percentage but actually it is giving right percentage based on your formula. May be your formula is not correct to calculate percentage as your numerator is total.
Along with that if you plot these 2 measures that you used inside your %, you will get below value and % is correct based on these values.
You can verify by going in table view and by selecting KAJX and Business and Industry. Please let me know what is wrong with these and I will be happy to help you to sort out.
AoA,
The Second picture what I have posted was, I want the calculations stopped at the Station level and should not go granular at the line item
or have the measure written in a way when even the line item is clicked it should be calculated with the total of their line item category such as
if the Business and Industry (line Item is is clicked ) it should be telling me average for Business and Industry.
Let me know if that make more sense to you or we can connect over email mohammedkhan11@gmail.com
And for your second part, there are many ways to achieve that. One way to to use switch statement. You can put conditions as you like. Below is just an example.
Hi @mohammedkhan11. It’s a little confusing when the post is marked as solved. Many members do not look at solved threads, so you’re issue might not be reviewed.
why aren’t they starting a new posting when they are asking a different question…so confusing…i think once the posting has been solved there should be a message you can’t post to this thread
@Greg Please enlighten me, can’t we club the requirements and place it in one thread or does it have to be separate thread meaning dissect it and then post it.
I’ll start a new thread for everyone convenience.
@hafizsultan Thank you for providing the solution @Greg I’ll post a new thread for the Grouping Requirement that I had.
I hope I will not receive any other replies from any other anonymous users coz it is not required … Their silence will be greatly appreciated.
Hi @mohammedkhan11, though we appreciate the detailed information you posted, I’m afraid this thread violated some forum rules.
We would like to emphasize that asking more than one question in a forum thread and posting questions that could take hours to answer are considered inappropriate.
While all our users and experts do their best to respond on a timely manner, we discourage demanding urgent answers. Please be patient, as this isn’t an on-demand forum. Response times will likely be anywhere between 12-48 hours.
