Paginated Reports
Just wondering if anyone is using Paginated Reports / Report builder?
Whether or not it might a good idea to have a separate forum category for all things related to it?
Hi @marcster_uk , we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @marcster_uk, we’ve noticed that no response has been received from you since the 16th of December. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Marking as solved.
