I am trying to figure out why the discrepancy in the output using Offset vs. Non-offset time intelligence.
Take for instance, Year-to-Date offset formula vs. DatesYTD formula. Why are the values different? See output in image #3. What am I doing wrong or missing? Thanks in advance.
Just following up if the response above help you solve your inquiry.
If it did, please mark Harsh answer as the SOLUTION.
We’ve noticed that no response was received from you on the post above. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
