I’m sure I’m doing a simple mistake, but solving this has been a bit difficult. As you can see, the percentages are clearly not calculating correctly. I’ve tried filtering the % column to be only “Domestic” value, but have not been able to make it work. Here is the .PBIX file: Airfair data.pbix (1.2 MB)
Hello @mdalton2100,
To achieve the correct percentage values. Below is the formula as well as screenshot of the results provided for the reference -
% of APC 14 day split (all types)_a2 - Harsh =
DIVIDE( [Count of Domestic tickets a2] ,
CALCULATE( [Count of Domestic tickets a2] , ALL('Air Travel v2'[Advance Purch _ 14 day flag] ) ) )
I’m also attaching the working of the PBIX file for the reference.
Thanks and Warm Regards,
Harsh
Airfair data - Harsh.pbix (1.2 MB)
Thank you Harsh, works beautifully. Appreciate the education on DAX.
Hello @mdalton2100,
You’re Welcome.
I’m glad that I was able to assist you and you found the solution helpful in your scenario.
Harsh
