New parts added
I have a table that contains Part Number, Added_date. This table goes back to 2002. Here is what I need to know.
First, I need to know whenever we enter a Part Number into our system(table) that has only been in our shop less than or equal to 5 times.
Second, I want to narrow that result down to just activity in the past 5 days. If 6 days ago, we entered a part for the fourth time since 2002, I don’t want to see it in my results. If we enter a part for the second time since 2002 three days ago, I want to see it.
I did this:
Count Part End As =
CALCULATE(COUNTA(WO_EXPEDITE[PART_ENDED_AS]), ALL(WO_EXPEDITE[ADDED_DTE]))
Then I put a visual relative filter on the Added_dte “is less than 6”. That seems to work if I am only displaying the Part_Ended_As and “Count Part End As” measure in the table visual but when I added another column, the work order number, the results became incorrect. What am I doing wrong or is there a better way to get this information?
I think here you want to use a combination of CALCULATE & FILTER.
The logic, to me, seems to sounds like this.
On any day you want to look back and see has any particular part had a sale (or similar calc) less than 4 times before. Then you want to see if this can be filter to just the last 5 days also.
I’m still not 100% sure how you want to show this in your report so I can only guess at the context.
Let’s start with the outline for the countback calculation.
As I mentioned I can only guess the context is products here.
So you should be able to simply go
Products Purchased = COUNTROWS( Sales )
This technique will get you the total number, then you can use a simple IF statement.
Products Purchased = IF( COUNTROWS( Sales ) > 150, BLANK(), COUNTROWS( Sales ) )
This will reduce the size of the table showing the results
For example
To then drill down the time frame,
You can do this with a simple CALCULATE function and include the
Product Pruchased Time Intelligence =
CALCULATE( [Products Purchased],
    DATESBETWEEN( Dates[Date], Date1, Date2 ) )
See how you go with these ideas.
Chrs
