Need help with Time Intelligence
Attached is a PBIX file that I have just about completed, but where I am having issues is developing a Measure that can count the number of remaining workdays in a selected month based on the current date. I have a measure that counts the number of workdays for the selected month, but because because I am using the month versus a date, I am struggling to calculate the remaining workdays of the selected month. I also need need to set the value to be zero workdays if the user selects a past month. Any help would be appreciated. Daily Doc.pbix (146.1 KB)
@lomorris,
Have to run to dinner, and haven’t had total time to check this, but give this a go:
Remaining Workdays Selected Month =
VAR LastDay=
    COUNTROWS( Dates ),
    FILTER(
        ALL( Dates ),
        Dates[MonthInCalendar] = SELECTEDVALUE( Dates[MonthInCalendar] )
VAR EndDate =
DATE(
    SELECTEDVALUE( Dates[Year] ),
    SELECTEDVALUE( Dates[MonthOfYear] ),
    LastDay
VAR WkDaysBtw =
    COUNTROWS( Dates ),
    DATESBETWEEN(
        Dates[Date],
        TODAY(),
        EndDate
    FILTER(
        Dates,
        Dates[IsWorkDay] = TRUE &&
        Dates[IsHoliday] = FALSE
VAR Result =
IF( EndDate < TODAY(), 0, WkDaysBtw )
Result
I hope this is helpful.
Brian, This worked perfectly. I am reviewing each line to see how it works. Thanks again for your help.
@lomorris,
Happy to help – glad that got you what you needed. If you have any questions as you run through the code, just give a shout.
– Brian
