Can I move columns while in table view? If not, can I only move columns around in query editor.
Cheers
e
Cheers
e
I would recommend you only doing data transformation in your query editor. That way you can go back to the data and see which transformations you did to it, or remove steps of data transformation.
Best regards,
Jorge Galindo
I normally would but I created a date table using DAX hence cannot change in query editor. Can I change the column around in table view in the Power BI.
I don’t quite understand, but let me know if you created the date table using the method Sam explains in his videos?
If not, I would recommend you going through this course to get a more flexible date table:
Here is the date table code:
Let me know if this helps.
Best regards,
Jorge Galindo
