Ok,
Now i will try to help you thanks for providing me the right understanding.
Thanks,
Anurag
Ok,
Thanks,
Anurag
Pls verify the result for the table and i think if this is right you can get other result with some modification in the dax :
For your reference i am attaching the PBIX:
AR_Aging-2022-01-06 (1).pbix (3.3 MB)
Let me know if this is the right result and if you need any other help.
Thanks,
Anurag
Looks perfect! Thank you!
OK ,
Glad to help you .
Pls mark the reply as solution so the thread will be closed.
Thanks,
Anurag
Thank you, very much!!!
Pls, Mark my reply as solution on which i provided you the solution .
So if anybody in future face same type of problem will know that my above reply conation the solution.
Thanks,
Anurag
Did it work?
HI there !
I have two follow up questions:
I do not able to reproduce your second issue i used the following dax:
A_LAST NOtE_1 =
VAR cus_ID=SELECTEDVALUE(‘GP_ AR Aging’[Document Number])
VAR max_dt=MAXX(FILTER(‘Collection Files with Note’,‘Collection Files with Note’[Document Number]=cus_ID),‘Collection Files with Note’[NoteDate] )
Var res=MAxx(FILTER(‘Collection Files with Note’,‘Collection Files with Note’[Document Number]=cus_ID &&‘Collection Files with Note’[NoteDate]=max_dt),‘Collection Files with Note’[Note])
return
if( ISINSCOPE(‘GP_ AR Aging’[Customer Number]),res)
For your first question :
You can use IsINscope function it will solve your 1 problem
Attaching the latest PBIX :
Hi Anurag
RE: second Note
A_LAST NOtE_1 =
return
It still not working, please see the message. I tried to change all IDs to text but it didn’t work either.
Sorry for so many trouble and questions, Thank you!
Hi @npower! We noticed that your inquiry was left unsolved for quite some time now.
