Month sort for column chart display
Hi folks,
I have some data from 09/2019 to current month. Despite having a reasonably comprehensive date table (provided), I’m having difficulty sorting a column chart to display data (from L to R) for Sept, Oct (2019) …… to Jan (2020). I’ve tested sorting the Calendar Table Date column using the CurMonthOffset column and that produces the correct L to R display but displays the CurMonthOffset values eg. -4, -3, -2 …. to 0. Zero being the current month, but I want the month names displayed and not other values that might be associated with the sort.
Any suggestions are more than welcome.
TIA john
PowerBIPro - CalendarTable.txt (7.7 KB)
@jmaikido,
Using your date table, if you sort your x-axis column by the MonthYearNum column you should get the result you want.
See sample below:
Hope this is helpful. Full solution file posted below.
Hi Brian
Thnx heaps …. it worked a treat
Simple … but I just couldn’t ‘see’ it
Regards,
John
@jmaikido,
Great – glad that was what you needed. I’ve been there too - enough times that I keep this cheat sheet on my desktop to keep the date table fields straight, and figure out which column I can use to sort which other columns.
