Has anyone created a membership or event (virtual event) based dashboard. I am doing a small presentation next week.
I work for a non-profit organization and need to speak to a membership or event-dashboard. I certainly can create one (need to generate) the data. Any guidance will be fantastic.
Thanks for posting your question @mbraun. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Hi @mbraun, we’ve noticed that no response has been received from you since the 22nd of October. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
