Measure previous week
I cannot cope with creating a measure. The measure should show units for the previous week.
Note: I cannot use calculated tables and columns because I have a live connection.
Week-1.pbix (43.7 KB)
@Harris
Previous Week =
VAR CurrentWeek =
    MAX ( DimDate[WeekInYear] )
VAR PreviousWeek =
    CALCULATE (
        MAX ( DimDate[WeekInYear] ),
        DimDate[WeekInYear] < CurrentWeek,
        REMOVEFILTERS ( DimDate )
VAR Result =
    CALCULATE (
        SUM ( Sales[Units] ),
        TREATAS ( { PreviousWeek }, DimDate[WeekInYear] )
    Result
or the below one considering your expertise with DAX.
Previous Week =
VAR CurrentWeek =
VAR PreviousWeek =
    CALCULATE (
VAR Result =
    CALCULATE ( SUM ( Sales[Units] ), DimDate[WeekInYear] = PreviousWeek )
    Result
I see there is already a response from @AntrikshSharma
but I wanted to contribute my thoughts and notes as well
  1. The date table provided in your sample is very thin, I recommend including a few more basic columns if possible, such as report that combines week and year as numbers
    Example for G2019, week 1 - I would have a column that shows 201901
    I would probably also include the year as a number, without the β€œG” included (this makes math a bit easier)
The first measure I came up with was similar to the second solution above:
Units in Prior Week =
VAR SelectedWeek = SELECTEDVALUE( DimDate[WeekInYear] )
VAR SelectedYear = SELECTEDVALUE( DimDate[CalendarYearName] )
CALCULATE( [Actual Units in Week],
FILTER( ALL( DimDate ),
DimDate[WeekInYear] = SelectedWeek -1 &&
DimDate[CalendarYearName] = SelectedYear))
But I noticed that this returned a blank on Week 1, so I modified it to this:
Units in Prior Week (dealing with year change) =
VAR YearAsNum = VALUE( RIGHT( SelectedYear, 4 ))
VAR NormalWeek =
VAR HandleWeek1 =
DimDate[WeekInYear] = 53 &&
DimDate[CalendarYearName] = CONCATENATE(β€œG”, YearAsNum - 1)))
IF( SelectedWeek = 1,
HandleWeek1,
NormalWeek )
Notice that because β€œYear” is a text value, with a G included, I had to do some fancy footwork to return the prior year for the "HandleWeek1 part of the measure)
eDNA Solution from Heather Week-1.pbix (44.4 KB)
@Heather Thanks for the idea. I added Year Week Number column and have updated my code. Harris.pbix (63.6 KB)
Previous Week =
VAR CurrentWeek =
    MAX ( DimDate[Year Week Number] )
VAR PreviousWeek =
    CALCULATE (
        MAX ( DimDate[Year Week Number] ),
        DimDate[Year Week Number] < CurrentWeek,
VAR Result =
    CALCULATE (
        TREATAS ( { PreviousWeek }, DimDate[Year Week Number] ),
    Result
Previous Week 2 =
VAR CurrentWeek =
VAR PreviousWeek =
    CALCULATE (
VAR Result =
    CALCULATE (
        DimDate[Year Week Number] = PreviousWeek,
    Result
Hello @nikahafiz,
Thank you for referencing a Forum Post to add context to your question. The Post you replied to has been closed for a number of years, and we would ask that you close this Reply and create a new post to handle your question.
Thanks!
