MAX Not calculating correctly with multiple user selections
Hi Fellow Power BI Users -
I have a table of historic overtime data for a list of locations by month and am trying to get the maximum overtime value to calculate correctly when multiple are selected by the end user
ie: in the below example should be showing 3388 but is showing 5493.
What am I missing?
Many Thanks
Richard
Ok yes, this one I believe is all to do with the context within the SUMMARIZE function.
When using variables the results are at a ROW context, but we need then in a FILTER context within the SUMMARIZE.
Can you try something.
Place the MAXOTHOURS inside a measure by itself.
Then reference that measure inside the SUMMARIZE after the return.
See if that improves it.
If not can you possibly add a demo resource and I can have a more detailed play around
Hi Sam
Many thanks! that seems to have done the trick. :smile: smile:
Context of DAX really is doing my head in!!
Richard
Yes this can be the most complex one to get the head around. Sometimes stumps me also.
