I have a report with a Measure that returns the number of days passed since each customer’s last purchase. Is there a way that I can automatically trigger a Mailchimp email when a customer is away for certain amount of days? Has anyone done this?
Hi @jmolina, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
When posting a topic with formula make sure that it is correctly formatted to preformated text </>.
Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
Hi @jmolina
I have searched however couldn’t find a way to send mails through MailChimp using Power BI. Will let you know if come across something. For your requirement, you can also use default “Set Data Alert” in Power BI, however for this you will need to setup one visual for each customer.
Ankit J
Yes you can acheive this using Microsoft’s Power Automate.
Microsoft Automate is used to manage and automate email marketing activities, including sending marketing emails, automated messages and targeted campaigns. Please check the below link for more details:
https://us.flow.microsoft.com/en-us/connectors/shared_mailchimp/mailchimp/
Using Power Automate, you can send an email when a Power BI data alert is triggered. Also notify relevant people when a Power BI data alert fires without you having to manually let them know. Anyone can sign up for 90 days free trial.
Hi @jmolina, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
