Matty
October 22, 2021, 12:35pm
1
Dear DNA Team,
I will appreciate your guidance or help as I am stuck and I am not 100% sure how can I tackle the topic.
Please find the attached file:
TextSplit.xlsx (17.4 KB)
From the table below:
The end result that I would like to get is:
I am only able to create the end result only for the rows 3-5 but not 1 till 5 using the example data table.
First I have added index o keep track of lines and I use Text.Split by seperator “-”.
Unfortunately, the row 1-2 don’t have any separator and the only way I thought to separate the wors is by using: Split Columns by Positions 0,57,77.
Do you have any idea how could I get the end result?
Thank you ,
Matty
Hi @Matty ,
Give this a go, just paste the script into a new blank query.
let
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("fZDdasQgEIVfZfBak9HRGC+XxBah2bQ6gYWQ93+Nul1S+rPJ3WHgfN/RdRWklVYGjRZStDlOqV0Kj+3wNvOSI1wWIA2owWhIV445coEhxzFxXHIBZyB08JIvqcAYb1wDQweI3zd4jYXTfIWKwbZaXJChE5tchemVOXebHtAcuckD2b9uDe7ETUH29st98O5Hk3OaftZrHObpnSN80B1jcGf4nfHrwxr0zcFojZKC2hfCPpskonqy+36udG1r6+FEFZ45scFw5CQnnf/vtNKdOW0NXmzbJw==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Date = _t, Description = _t, Amount = _t]),
AddCustom = Table.AddColumn( Source, "Text", each
if Text.EndsWith([Description], "-") then List.Transform( List.RemoveMatchingItems( Text.Split( [Description], "-"), {"", null} ), Text.Trim ) else
let
myDescr = [Description],
mySplit = Splitter.SplitTextByAnyDelimiter( {"0".."9"} ),
myList = List.Select( mySplit(Text.RemoveRange([Description], Text.Length([Description])-1)), each Value.FromText(_) is text ),
SkipAfter = List.Select( myList, each Text.EndsWith( Text.Trim(_), " AU" )),
lPos = List.PositionOf( myList, SkipAfter{0}? ),
FinalList = if lPos = -1 then myList else List.RemoveItems( myList, {myList{lPos+1}} ),
Result = Splitter.SplitTextByPositions( List.Transform( FinalList, each Text.PositionOf( myDescr, _)))
in
List.Transform( Result( myDescr ), Text.Trim )
ExpandText = Table.ExpandListColumn(AddCustom, "Text")
in
ExpandText
It’s not pretty but does seem to do the trick.
Here’s the result.
I hope this is helpful
Matty
October 23, 2021, 10:30am
3
Melissa:
let
let
in
in
ExpandText
Thank you @Melissa it worked on smaller scale of the data, but on larger scale I get duplicates I think the issue is when I have blank instead of “- ” as an separator.
I have an question , would be interested in giving private lesson regarding m-code? Obviously not for free ?
Thank you,
Matty
Thanks @DavieJoe for supplying a link to the PQ M Course.
@Matty , I hope you’ll enjoy that.
Q: Can you provide a larger sample that generates this unwanted duplication so I can look into that?
All the best.
Hello @Matty , a gentle follow up on Melissa’s request.
We noticed that no response from you was seen since October 23rd.
Hi @Matty , due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, please create a new thread.
Matty
December 16, 2021, 11:24pm
8
@Melissa Apologise for coming back , I just read this now.
To be honest, I was not logging for some time, I was studying towards my ACCA exams.
I could provide it, but around in January . Currently I am just too busy with work and exams .
Thank you,
Matty
Melissa
December 17, 2021, 6:48am
9
No worries @Matty ,
Just create a new, follow up topic when your ready.
Best of luck with your exams!
