Integrate into Office 365 Calendar
I am looking to create some dashboards that pull from our Office 365 user calendars. Have you done anything like this? We have purchased a connector from CData.
I have used the following connection to get data from my Outlook Calendar:
Here is good article I read that shows you how to connect and manipulate data:
thank you for the tip. I have connected. However, there area number of columns in the Calendar table that don’t get pulled into the report. In edit query, they are actually yellow. The column i need is Categories and it is one that is not pulling over.
the report…category is missing.
what does it mean when a column is yellow in the Edit Query window?
never mind, i figured it out. You have to hit the expand button in the column heading and then it will push the data over.
You got it! Usually when yellow it will expand, and then you can choose what to bring into the model.
