Input Field Churn
Not able to create Churn field to input the No.
Churn Time Frame is a Table
  • Within a Table Column is selected - Churn Time Frame
  • Measure is written - Churn time Frame Value
@Rohit1 You will need to provide more detail on your question for it to be answered properly. If you can review the below link and it will be the perfect guide to getting your question answered.
Asking Questions On The Enterprise DNA Support Forum - Forum Guides - Enterprise DNA Forum
Hi @Rohit1, adding up to what @DavieJoe mentioned above.
I noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
  1. A clear explanation of the problem you are experiencing
  2. A mockup of the results you want to achieve
  3. Your current work-in-progress PBIX file
  4. Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
Hi @rohit1, we’ve noticed that no response has been received from you since the 21st of June.
We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
