Iwona
February 14, 2023, 3:36pm
1
Hi all ,
I would like to request help with my two calculations ( Cal1 and Calc2 marked yellow in the picture below)
So far I have only this in PBI
My main problem is a measure of the average company without context - nothing gives me the correct value because of that I am unable to achieve Cal1 and Calc 2 marked yellow in the first picture.
I have attached : two table ( key is Employee ID) and PBI file with my existing work.
Holiday details_forum.xlsx (59.6 KB)
Employee details_forum.csv (33.1 KB)
Holidays_forum.pbix (63.3 KB)
Could I kindly please for help?
Grateful as always,
Iwona
Melissa
February 14, 2023, 7:41pm
2
Hi @Iwona ,
Thanks for the clear description and files
Quick note.
You used an implicit measure in your table for Total holidays . As best practice make a habbit to always create explicit measures.
You’ll want to review the Calc1 measure because I had to round the Avg total to match the expected outcome.
Calc1 =
[Total Holiday] * ROUND( [Avg total], 2 )
with this result.
Here’s your sample.
Holidays_forum.pbix (64.1 KB)
I hope this is helpful
Hello @Iwona ,
Did the response from @Melissa help solve your query?
If it did, please mark her answer as the SOLUTION.
Thank you
