HI,
Some of my logistics team at work cant type properly nor should they need to type as i supplied barcodes to get this data correct.
Basically the Kanban location data is a mess and needs to be cleaned up some how. What i am looking for is an easy way to fix the formatting properly
Each location should be formatted the same such as FBU - A330 Aileron - 05 now as you can see from the photo some people have been putting FBU - A330 Aileron-05
Is there a way to have query editor check all the entry’s and adjust.
Dan
