I have created a table showing opportunity stage, seller name, and countrows of opportunities. On the seller name I have checked off “show items with no data.” When I copy the table and and change it to a pie chart to only show opportunity stage and countrow opportunities, I can no longer see blank. What would be the appropriate measure to create so I can count the total number of blanks?
What I am trying to do is show which sellers have no opportunities for a national vendor.
Hopefully I explained what I am looking for thoroughly. I am new to DAX and struggling to find the measure that would help me.
Hi @aliciab83, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
share the pbix for better understanding.
But what i get from your description is, you need to use BLANK() function in if else condition.
some thing like that : Table[ column name] = BLANK() or ISBLANK function
Hi @aliciab83, we noticed that you have not responded to our request above. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
