How to turn measures into columns?
I have these following calculated measures shown below:
My question is how I can turn them into columns, like this?
I can’t do this transformation in power query since these are measures, not calculated columns. So I’m stuck right now.
Thanks for your help
Choose the Matrix visual and go to the format options in the Values section and enable “Show on rows
I hope this is helplful
Hi @ctvv3010, did the response provided by @Melissa help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
Hi @ctvv3010, we’ve noticed that no response has been received from you since the 22nd of January. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
