How to reorganize data which were formatted by using validated facility codes
Hi Team,
I have data model on “Data” sheet getting life data from ERP and some assumptions.
I just want to have result of all the accounts from Data page for all facilities codes (1024,1025,1026,1027,1028) from Validation list.
Can we try that in Power Query? Or is there any way to do that?
Expected Result page is attached.
SolutionMaskedDataforRevenueModel.xlsx (127.1 KB)
Thank you.
Regards,
Aye
Hi @ammu, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
  • Include the masked demo pbix file and any other supporting links and details.
Hi @ammu, we’ve noticed that no response has been received from you since the 22nd of March. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
