Help, please
I cannot figure out why the SELECTED YEAR ACTUALS value are not showing in the breakdown by year in matrix visuals.
Thank you.
Help, please
Thank you.
Your date table relation is not right may be becuse the data type of both is not same as you can see in the below screen shot :
When i put your month and date side by side only balnk come from date table
The reason is month is text format and date is date type which is not correct .
You need to change the text to date and that you can do it on M side or in Table view choice is your and report will start giving you the desired result as shown in the below screen shot:
Let me know if i need to share the PBIX then i will .
Thanks,
Anurag
Hi Anurag
Thank you for your feedback.
I see your point on text vs date data types.
Many thanks. SOLVED!
I thought I did point the SOLVED in the thread.
Did I miss it?
