How to find Top 50 Softwares across each Applications
Hi All,
Looking for some help here, i have a table which has Application Information and Softwares Information and each Application has Mulitple softwares.
What are the Top 50 softwares we are using at each application?
Attached is the PBI file for your reference.
Top 50 Softwares.pbix (71.9 KB)
Regards
Nag
Does this work for you?
Top 50 Softwares v1.1.pbix (73.3 KB)
No , i was looking for Top 50 software’s list which we are using not the count.
If you looked at the table ive posted, it’s is filtered down to the Top 50.
I just left the count in so you could order it.
Thank you
No worries, have a great day!
