How to delete a constant number continously in DAX
Hi ,
I wanted to calculate the below senario through DAX so it will be dynamic.
I have two table table1 and table 2 both are disconnected.
Table1 has
Value
5
10
20
Table2 has
Value
50
Now i want to delete table2 from table1
And expecting below output"
result
50-5=45
45-10=35
35-20=15
the subtract should happen on the previous obtain number.
Pls ,guide me .
Thanks,
Anurag
Hi @Anurag,
Your requirement isn’t very clear but give this a go and see if it gets you there:
I started with the 2 tables you’ve described, both have 1 column called “Value”.
I hope this is helpful.
Thanks for the answerer, I am also trying to use Earlier but getting some error .
Just one question how your earlier function get the context of table1.
Pls , enlighten me about this .
Thanks,
Anurag
Hi @Anurag,
I guess you are trying to write a measure… if so, try this
