How to create Template solution
How can I create a template solution and distribute to the business community with base data model, proper naming convention and reuse it as a starting point for other development work?
This is very simple,
All you have to do is export as a ‘template’
Can we review how to post forum posts please. Need to make sure these are categorized - https://forum.enterprisedna.co/t/how-to-ask-support-questions-on-the-forum/30
Thank you Sam. I will try that.
