Hierarchies or path function
Hey guys,
I have this table with accounts id :
and i want to achieve something like this
Capture1
I did it in the wrong way, because there’s more levels than i expected, as many as GroupingCategory is like “GA”. And “GA” can have 3 digits, or 4 or 5. “GR” has always 2 digits and GM is movements.
I’m attaching an excel file for you tom take a look and try to help me better.
1 more thing, please notice that this file is missing the groupingCode with 1 digit in all accounts.
Thank you all
PedroDNA Paths.xlsx (10.0 KB)
Hi @pedroccamara, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
