I`m trying to figure out how i can project forwards the work completed in one area of my business to the next areas planned work load for the following week.
See attached screen shot and PBIX i have 7 areas in my business that process parts one after another week to week. Each area is shown with a sequence number.
As an example ill use number 1 process CCA.
In week 36 the CCA actual was 254 parts the following week, week 37 i want those 254 parts to be the plan for sequence 2 Autoclave and then in week 38 whatever the Autoclave finishes should be the plan for CNC area sequence 3.
This trend should continue for all areas that what ever is finished should be the plan for the next sequenced area the following week.
Hi @Krays23, a response on this post has been tagged as āSolutionā. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks
I had the same problems with the preformatted text, and @Nick_M figured it out. If you put a blank line between the first line ( measure name = ) and the start of your DAX code, the preformatting option will work perfectly.
Iāve added a Measure [Plan v3], so it now shows [Actual] where the Sequence = 1
Just wrapped it in an IF statement, so you can change that easily should the need ariseā¦
Hi @Krays23, weāve noticed that no response has been received from you since December 16, 2019. We just want to check if you still need further help on this post? In case there wonāt be any activity on it in the next few days, weāll be tagging this post as Solved. You may reopen a new thread when the need arises.
