Solver
Solver is a What-If Analysis tool in Microsoft Excel that helps you find the optimal solution for a specific problem by changing multiple variables in a spreadsheet. It is used when you have a complex problem with multiple variables and constraints and want to find the best possible solution. Solver is a tool that uses mathematical algorithms to analyze data and generate solutions based on certain criteria or constraints.
Goals
Please follow the directions given below, which include downloading the Excel worksheet required to perform the challenge tasks. Once you have completed the download, proceed to take the challenge and test your skills.
Task
Minimize the delivery expenses by devising a plan for distributing goods from 2 warehouses to stores (D24).
This plan should consider both the quantity of goods required by each store and the capacity of the warehouses.
Submission
Reply to this post with your formula code and solution file. Please be sure to blur or hide your formula code.
This was definitely a challenging one for me. That’s because i have not used it before. I had to watch some tutorials on YouTube to fully grasp it. Thanks for this challenge @IlgarZarbaliyev . I learnt something new. Excel wizard @borydobon , I have seen your formula approach and it’s quite phenomenal.
Thank you for participating in the Excel Challenge related to Solver Add-In!
I hope you found this challenge to be a fun and engaging way to improve your Excel skills and learn more about how to work with Solver in Excel.
Select cell D24.
Enter the next formula: =SUM(C11:G11C18:G18)+SUM(C12:G12C19:G19)
Click on File Tab. Then, select More, Options, Add-Ins, Manage, Excel Add-Ins and click on Go. Check Solver.
