Hi, has anyone mastered how to set-up a connection within Excel to pull data from a dataflow? Microsoft have been promosing this functionality for a while but nothing has been delivered yet.
I don’t mean Analyse in Excel which is useful, i am looking for a refreshable Excel data connection that will pull in my data from a dataflow.
Yea i realise the MS team have not yet published this yet but i just wondered whether the smart people on this forum had found a way to do this like a custom connection or something. Thanks
Hi @BCS, did the response provided by @Keith help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @BCS, we’ve noticed that no response has been received from you since July 4th. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @BCS, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
