LinkedIn Post by:
Surendra Reddy
=MAP(A2:A6,LAMBDA(x,TEXTJOIN("-",,REPT(MID(x,SEQUENCE(LEN(x)),1),SEQUENCE(LEN(x))))))
=BYROW(A2:A6,LAMBDA(_range,LET(_split,MID(_range,SEQUENCE(LEN(_range)),1),_seq,SEQUENCE(LEN(_range)),_result,TEXTJOIN("-",,REPT(_split,_seq)),_result)))
here is what come to my mind
=MAP(A2:A6,LAMBDA(x,TEXTJOIN("-",TRUE,REPT(MID(x,SEQUENCE(LEN(x),1,1),1),SEQUENCE(LEN(x),,1,1)))))
=MAP(A2:A6,LAMBDA(a,LET(s,SEQUENCE(LEN(a)),TEXTJOIN("-",,REPT(MID(a,s,1),s)))))
LinkedIn Post by:
Hi to all!
One option could be:
=MAP(A2:A6,LAMBDA(x,TEXTJOIN("-",,REPT(MID(x,ROW(1:9),1),ROW(1:9)))))
Blessings!
Today was quite a nice breather, with the REPT function.
=MAP(A2:A6,LAMBDA(X,LET(A,X,
B, SEQUENCE(LEN(A)),
TEXTJOIN("-",,REPT(MID(A,B,1),B)))))
LinkedIn Post by:
hi everyone, my proposal solution:
=MAP(A2:A6, LAMBDA(a, LET(_s, SEQUENCE(, 5), TEXTJOIN("-", 1, REPT(MID(a,_s, 1),_s)))))
Envio mi soluccion
=UNIRCADENAS("-";VERDADERO;LET(a;EXTRAE(A2;SECUENCIA(LARGO(A2));1);b;FILAS(a);c;SECUENCIA(b);REPETIR(a;c)))
=BYROW(A2:A6,LAMBDA(x,LET(l,SEQUENCE(LEN(x)),TEXTJOIN("-",,REPT(MID(x,l,1),l)))))
=SUBSTITUTE(TRIM(REDUCE("",SEQUENCE(9),LAMBDA(a,n,a&" "&REPT(MID(A2:A6,n,1),n))))," ","-")
LinkedIn post by:
=MAP(A2:A6,LAMBDA(a,TEXTJOIN("-",1,REDUCE("",SEQUENCE(LEN(a)),LAMBDA(i,j,VSTACK(i,REPT(MID(a,j,1),j)))))))
Thank you Excel BI
=MAP(A2:A6, LAMBDA(x, LET(a, SEQUENCE(LEN(x)), TEXTJOIN("-",, REPT(MID(x,a,1), a)))))
=MAP(A2:A6,LAMBDA(a,TEXTJOIN("-",TRUE,REPT(MID(a,SEQUENCE(LEN(a)),1),FIND(MID(a,SEQUENCE(LEN(a)),1),a)))))
Edit :
Only works for single letter occurrence…
This one should give more accurate results :
=MAP(A2:A6,LAMBDA(a,TEXTJOIN("-",TRUE,REPT(MID(a,SEQUENCE(LEN(a)),1),SEQUENCE(LEN(a))))))
Bonus :
Revert From the answer to initial String :
=MAP(B2:B6,LAMBDA(a,TEXTJOIN("",TRUE,LEFT(TEXTSPLIT(a,"-")))))
