Error on Combine and transform
I get this error when I run the script. O interestingly it affects the four last files in eth folder (when in alpha sort).
Error = An error occurred in the ‘Transform File (2)’ query. Expression.Error: The column ‘r_ReportDate’ of the table wasn’t found.
Details: r_ReportDate
Does anyone have any ideas?
Allister
let
Source = #“Folder Parameter”,
#“Filtered Hidden Files1” = Table.SelectRows(Source, each [Attributes]?[Hidden]? <> true),
#“Invoke Custom Function1” = Table.AddColumn(#“Filtered Hidden Files1”, “Transform File (2)”, each #“Transform File (2)”([Content])),
#“Renamed Columns1” = Table.RenameColumns(#“Invoke Custom Function1”, {“Name”, “Source.Name”}),
#“Removed Other Columns1” = Table.SelectColumns(#“Renamed Columns1”, {“Source.Name”, “Transform File (2)”}),
#“Expanded Transform File (2)” = Table.ExpandTableColumn(#“Removed Other Columns1”, “Transform File (2)”, {“r_ReportDate”, “r_ReportFreq”, “R_ReportLastReportDate”, “r_ReportPeriod”, “r_Version”}, {“r_ReportDate”, “r_ReportFreq”, “R_ReportLastReportDate”, “r_ReportPeriod”, “r_Version”}),
#“Added Custom” = Table.AddColumn(#“Expanded Transform File (2)”, “Custom”, each Text.Start([Source.Name],3)),
#“Reordered Columns” = Table.ReorderColumns(#“Added Custom”,{“Source.Name”, “Custom”, “r_ReportDate”, “r_ReportFreq”, “R_ReportLastReportDate”, “r_ReportPeriod”, “r_Version”}),
#“Renamed Columns” = Table.RenameColumns(#“Reordered Columns”,{{“Custom”, “Branch Code”}}),
#“Source Name” = #“Renamed Columns”{13}[Source.Name]
in
#“Source Name”
@AllisterB,
The error indicates below:
So, it seems that in one of those affected files, this column(r_ReportDate) does not exist and that is why you are getting this error.
Please provide some more context if it is not the case.
Kind Regards,
Hafiz
Thanks for posting your question @AllisterB. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Thank you
Is it likely that the file at fault is the first one in the alphasort of files in the folder not to be imported. Does PQ stops importing more data if it comes across a file that has a fault?
Hi @AllisterB,
I’d suggest to use the #table intrinsic to define an empty table with same data structure and use that to replace possible error values in the #“Expanded Transform File (2)” step
try Table.ExpandTableColumn(#"Removed Other Columns1",
    "Transform File (2)",
        {"r_ReportDate", "r_ReportFreq", "R_ReportLastReportDate", "r_ReportPeriod", "r_Version"},
otherwise
    #table(
I hope this is helpful
Hi @AllisterB, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
