I’m going to add my 2cents here. Go back to your source and see if you can have them changed before the file is created. I can foresee major issues later on here by changing them later.
If they can’t be changed then the user needs to understand there are limitation.
Due to inactivity, a response on this post has been tagged as “Solution”.
