I posted a smilar post where I wanted help with a Dynamic Age Banding issue, which looks like it is now fixed.
The attached pbix file has a visual Clustered column chart (Headcount by Age Band) where I want to show the Headcount for each Age Band, this will also change results when the Years have been changed, but the Headcount is showing the same value of 11 for each Age Band.
Why is it not showing the what the headcount is for each Age band category?
Any ideas?
Dynamic Calculate Age and Headcount.pbix (180.9 KB)
Hi @denwo1982
Thank you very much for posting your query in the forum.
I have created the following measure to calculate the Number of Employees for each age range:
# of Employee by Age Band_JAFP =
VAR _CurrentAgeBand = MAX( 'Age Band Desc'[Age Band] )
VAR _EmployeeandAgeRange = ADDCOLUMNS(
VALUES( Employee[Employment Id] ),
"@Age Range", [Age Range_JAFP]
VAR _Result = COUNTROWS(
FILTER(
_EmployeeandAgeRange,
[@Age Range] = _CurrentAgeBand
_Result
Age Range_JAFP =
VAR _Age = [Age]
VAR _Result = CALCULATE(
VALUES( 'Age Band Desc'[Age Band] ),
FILTER(
'Age Band Desc',
'Age Band Desc'[Start] <= _Age &&
'Age Band Desc'[End] >= _Age
_Result
Regards,
Dynamic Calculate Age and Headcount_JAFP.pbix (190.9 KB)
Hi @jafernandezpuga
Thanks for your reply, Iβve had a look at your latest report but it is not returning the correct results I am expecting to see for the Headcount and what it is for that Age Band for that time of Year.
If you look at the below image that is what the headcount should be for each age band and for the year it is in
So for the Year 2022
I was expecting to see the below counts
β20 - 30β = 4
β31 - 40β = 5
β41 - 50β = 2
and all the other age bandings would be zero
But on yours it is showingβ¦
β20 - 30β = 5
β31 - 40β = 7
β41 - 50β = 2
It looks like it is including in the Headcount the Employees that have Left (Employment End Date)
Hi @denwo1982 ,
I share a possible solution that I have been working on. I hope it can be of help to you.
Measures:
Age Range by Employee =
VAR _Employees =
CALCULATETABLE(
'Employee'[Employment Start Date] <= MAX( 'Calendar'[Date] ) &&
ISBLANK( 'Employee'[Employment End Date] ) ||
'Employee'[Employment End Date] > MAX( Calendar[Date] )
VAR _CurrentEmployee = MAX( Employee[Employment Id] )
VAR _Age = [Age]
FILTER(
'Age Band Desc',
IF(
_CurrentEmployee IN _Employees,
_Result,
BLANK()
# of Employee by Age Band Totals =
VAR _CurrentYear = MAX( 'Calendar'[Date].[Year] )
VAR _Employees = CALCULATETABLE(
VAR _EmployeesandAgeRange = FILTER(
ADDCOLUMNS(
CROSSJOIN(
_Employees,
VALUES( 'Calendar'[Date].[Year] )
"@Age Range", [Age Range by Employee]
NOT ISBLANK( [@Age Range] )
VAR _Result = SWITCH(
TRUE(),
ISINSCOPE( 'Age Band Desc'[Age Band] ) &&
ISINSCOPE( 'Calendar'[Date].[Year] ),
COUNTROWS(
FILTER(
_EmployeesandAgeRange,
[@Age Range] = _CurrentAgeBand &&
'Calendar'[Date].[Year] = _CurrentYear
NOT ISINSCOPE( 'Age Band Desc'[Age Band] ) &&
COUNTROWS(
FILTER(
NOT ISINSCOPE( 'Calendar'[Date].[Year] ),
COUNTROWS(
FILTER(
_Result + 0
Regards
Dynamic Calculate Age and Headcount_JAFP.pbix (177.3 KB)
Thanks @jafernandezpuga yes that looks good now, nice work! Excellent!
Hi @jafernandezpuga how would I be able to drill through to the detail of the Employees that belong to that Age Band? Or is it not possible because it uses a Dynamic Segregation?
Would I have to redesign my model?
Hi @denwo1982,
We can create a Tooltip and in the Age by Employment graph, add the filter Age Range by Employee in not blank.
Regards,
Dynamic Calculate Age and Headcount_JAFP.pbix (176.8 KB)
