I am trying to figure out, I have a use case where customers get loyalty points when they buy stuff.
We 3 levels of loyalty:
Not yet Qualified – 0 - 2500 points
Base – between 2500 - 20000 points
Executive – > More than 20000 points
I am able to achieve how many customers are in different category by using dynamic grouping.
but now I want to find how many customers are close to get to the next level. Something like:
Within 0 - 10% to get to Base (which means points greater than 2250 but less than 2500)
Within 10 - 20% to get to Base (which means points greater than 2000 but less than 2250)
Within 20 - 30% to get to Base (which means points greater than 1750 but less than 2000)
Within 0 - 10% to get to Executive (which means points greater than 18,000 but less than 20000)
Within 10 - 20% to get to Executive (which means points greater than 16,000 but less than 18,000)
Within 20 - 30% to get to Executive (which means points greater than 14,000 but less than 16,000) so on and so forth.
I put the sample file here:
Just to give an example: In this example, 4 are executive, 33 are base and 761 are not qualified.
For e.g.: In base category, there is 1 customer who is within the threshold of 10% to achieve Executive status (3584605). I want a count that customer in that bucket.
Hi @rit372002. It looks like you’re well on your way already. I’d think if you create another disconneted table for your second-level groupings (e.g., [Within 0 - 10% to get to Base, Min > 2250, Max <= 2500]; [Within 10 - 20% to get to Base, Min > 2000, Max <= 2250)]; etc.) then another [My Groupings 2] measure that uses this new disconnected table, you’ll get what you want. Give this a try, and, if you’re still having issues, upload the revised PBIX for the forum members to review along with a marked-up screenshot of the current visual or Excel mockup showing the desired outcome.
Hi @rit372002, did the response provided by @Greg help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
I hope that you are having a great experience using the Support Forum so far. We’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
Hi @rit372002, we’ve noticed that no response has been received from you since the 20th of May. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @rit372002, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
