I’m working with call center data and would like to create a column that describes how many seconds each caller is stuck in the queue while waiting to be connected with an agent. The data is extracted as a flat excel file, in the following format:
When I pull this datafile into power query, this column is automatically converted into a time format, and I can’t figure out how to covert it into duration. When I do select data type = duration, it returns an error.
In order to achieve the results based on the scenario that you’ve specified. Below are the steps listed as follows -
1). When data is imported in Power Query. By default, it’ll convert the “Inqueue Time” column into a “Time” data type. Below is the screenshot of the code generated by default inside Power Query upon loading the data (See the highlighted red box in the image) -
