Downloading Report
Help! I published a report to PowerBi Service from the desktop application. Somehow I lost the most current report in the desktop version. Can I download the report from the service into Power Bi Desktop to continue building?
@stiefel.ed ,
Yes, you can. Just open the report in the service, then go to File, Download the PBIX file (see screenshot below)
– Brian
Hi @stiefel.ed, did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @stiefel.ed, we’ve noticed that no response has been received from you since July 13th. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @stiefel.ed, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
