Hi I am very new to this course, I didn’t work any data analyst field, please help me how many topics I need cover to finish power BI course, and I want to know after I finish topics can I get certificate?
Welcome to the forum - great to have you here!
There is so much content on this site, that I definitely understand how it can be confusing trying to figure out where to start. In order to help guide you, we have created the Enterprise DNA Learning Map, which you can find here:
This map provides a recommended order of study, from the very first course all the way through certification. If certification is your end goal, you can see here what the steps are necessary to gain that formal certification:
I hope that’s helpful.
- Brian
Hi @ushachandrashekara , did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @ushachandrashekara, we’ve noticed that no response has been received from you since the 22nd of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @ushachandrashekara, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
