Double filtering & Context
Dear Enterprise DNA forum,
I would like your advice on the following extracted from a wider analysis.
Let say I am analysing project network data, from a scheduling software and comparing results for various updates.
The raw data is in one table and the have format/structure as below
Where:
• Activity ID – Does represent the unique identifier for each task in the project network;
• Project Ref – Does represent the various project updates (1,2, etc…); and
• Float – Does represent the float calculation extracted from the planning tool.
I do need to extract for each schedule update (project Ref) the activities that have float within a range
The float reference is the one of the last task of the network, let say the task with activity ID “A1100”, and should for each project compare with a range +/- 5 as below table
Ranges
At this point for all the activities that have a float with the range defined by the min and max (different for each project) as above in the cross matrix I need to show the value as below snapshot
DesiredOutcome
if some task have float value not within the range, for all projects, they will not been shown.
I attach here the PBIX file with the raw data and some of the analysis I tried to do, but I got the following result, that is not the desired one
PowerBIOutcome
Using a cross matrix defined as
CrossMatrixDefinition
And the “SelectedTF” DAX parameter defined as
In the PBIX file there are also other attempts to solve the problem, but I do think they are more far away from the solution, so I have not introduced them
Thanks in advance for your support
Regards
Luca
PBIX File: Test001.pbix (26.9 KB)
Hi @LucaB72,
See how this works for you.
After overwriting the Activity ID you have to bring back the Project context.
Here’s your sample file. Test001.pbix (29.9 KB)
I hope this is helpful
Awesome,
Thanks spot on.
I would never though to bring back the context of the project by using the values function
luca
