Hello. Welcome to another great workout. This is a 3-star workout.
In the workout, you will need to create a couple of measures to highlight the Top N Sales and the Bottom N Costs.
Pick your own colors.
But, have the number of the highlighted values change dynamically.
Good luck and I am looking forward to the results.
Submission
Load the supplied data file into a new Power BI file, create your solution, and reply to this post. Upload a screenshot of your solution along with the DAX measure. Please format your DAX code and blur it or place it in a hidden section.
Period
This workout will be released on Thursday, April 6, 2023, and will end on Sunday, April 9, 2023. But you can always come back to any of the workouts and solve them.
DAX _6 Highlight Top Bottom N.pbix (553.4 KB)
BrianJ
April 6, 2023, 10:15pm
#2
@Paul ,
Great workout! Hereâs my solution.
In honor of springtime in D.C., colors used were âLawnGreenâ and âThistleâ.
Click for DAX Code
CF Total Sales =
VAR __vTable =
TOPN(
[Number of Highlighted Products Value],
ALL(Products),
[Total Sales],
DESC
VAR __ProdCol =
SELECTCOLUMNS(__vTable, "@Prod", Products[Product Name] )
VAR __Result =
IF(
SELECTEDVALUE( Products[Product Name] ) IN __ProdCol,
"LawnGreen",
BLANK()
RETURN __Result
CF Total Costs =
VAR __vTable =
TOPN(
ALL(Products),
[Total Costs],
ASC
VAR __ProdCol =
VAR __Result =
IF(
"Thistle",
BLANK()
RETURN __Result
@BrianJ awesome job!! Yes they are fitting colors for DC springtime.
Anurag
April 7, 2023, 2:58am
#4
Hi ,
Here is my submission for the workout
DAX CODE
TopSale =
VAR _val=[Parameter Value]
VAR tb =
TOPN ( _val, ALL ( Products ), [Total Sales] )
IF (
COUNTROWS (
FILTER ( tb, [Product Name] = SELECTEDVALUE ( Products[Product Name] ) )
) > 0,
"GREEN"
BottomCost =
VAR tb =
TOPN ( _val, ALL ( Products ), [Total Costs], ASC )
IF (
COUNTROWS (
) > 0,
"Orange"
DAX _6 Highlight Top Bottom N.pbix (559.1 KB)
mbraun
April 7, 2023, 3:30pm
#6
Love these one off DAX. Here is my entry. You can see on the âMainâ tab the table and highlighting and then on the Methodology tab I walked through how I accomplished it.
DAX Workout No6 MB.pbix (1.2 MB)
Eze
April 8, 2023, 3:44pm
#7
Here is my submission, the more I go through other solutions, the more I learn. Thanks all
DAX Code
TopNSales =
VAR _Number = SELECTEDVALUE(âNumber of Metricsâ[Number of Metrics])
VAR _Ranking = RANKX(ALL(Products),[Total Sales],DESC)
VAR _TopN = IF (_Ranking <= _Number,[Total Sales],BLANK())
VAR _Result = IF ([Total Sales] = _TopN, âlightGreenâ)
_Result
BottomNCosts =
VAR _Ranking = RANKX(ALL(Products),[Total Costs],ASC)
VAR _BottomN = IF (_Ranking <= _Number,[Total Costs],BLANK())
VAR _Result = IF ([Total Costs] = _BottomN, âSalmonâ)
_Result
I picked colorblind safe red and green.
DAX _6 AlexisOlson.pbix (556.7 KB)
Top N Sales
Solution using TOPN:
Color Top N Sales =
VAR _N = [N] /*From parameter slicer*/
VAR _CurrProduct = SELECTEDVALUE ( Products[Index] )
VAR _AllSales_ =
ADDCOLUMNS (
ALLSELECTED ( Products ),
"@Sales", [Total Sales]
VAR _TopProducts_ =
SELECTCOLUMNS (
TOPN ( _N, _AllSales_, [@Sales] ),
Products[Index] /*Return only this column*/
VAR _Result =
IF ( _CurrProduct IN _TopProducts_, "#57c4ad" )
_Result
Bottom N Cost
Solution using RANKX:
Color Bottom N Costs =
VAR _Rank = RANKX ( ALLSELECTED ( Products ), [Total Costs], , ASC )
VAR _Result = IF ( _Rank <= _N, "#db4325" )
_Result
BrianJ
April 8, 2023, 8:07pm
#9
@AlexisOlson ,
Great to see you here! Really like the way you took one approach for the top products and a different approach for the bottom products.
Also, great point about making colors colorblind accessible.
Hi All,
Here are the steps I used for this workout:
Highlight Top N Sales
Highlight Top N Sales =
var _SalesRanking =
RANKX(
ALLSELECTED(Products),
[Total Sales],
DESC
var _SalesHiglight = [Number of Highlighted Products Value]
var _Result =
SWITCH(
TRUE(),
_SalesRanking <= _SalesHiglight, "#A9D18E"
return
_Result
Another measure to define color for bottom N Costs based on slicer:
Highlight Bottom N Costs
Highlight Bottom N Costs =
var _BottomCostRanking =
RANKX(
[Total Costs],
ASC
var _Result =
SWITCH(
TRUE(),
_BottomCostRanking <= _SalesHiglight, "#8FAADC"
return
_Result
Apply conditional formatting in Total Sales, background color, field value, Highlight Top N Sales
Apply conditional formatting in Total Costs, background color, field value, Highlight Bottom N Costs
Definitely enjoyed this one. And I wanted to take it a bit further by adding in a gradient of the colors. So you can see that the top sales has the darker green, but there is a slight gradient for others.
My Approach
Create the Numeric Parameter from 1 to 5 and used as a slicer.
Created a table of 5 items which included a Item #, and then a column each for my green and red colors that would be used for the gradient.
Created a measure for the Top N Sales (to be done in Green)
Created a second measure for the Bottom N Sales (to be done in Red) - this is exactly the same as above with the exception that changes the order for the RANKX function (highlighted areas).
And this results in the outcome. Iâm showing 5 items so you can see the gradient.
Dharma
April 9, 2023, 2:27pm
#12
@Paul.Gerber
Here is my Submission
TopNSales =
VAR _SelectedRank = SELECTEDVALUE(Parameter[Number of Highlighted Values])
VAR _TopNSales = RANKX(ALL(Products), [Total Sales], ,DESC)
VAR _Condition = IF(_TopNSales<=_SelectedRank, âLight Greenâ)
Return
_Condition
BottomNCost =
VAR _TopNSales = RANKX(ALL(Products), [Total Sales], ,ASC)
VAR _Condition = IF(_TopNSales<=_SelectedRank, âCoralâ)
Return
_Condition
DAX _6 Highlight Top Bottom N.pbix (562.7 KB)
KimC
April 10, 2023, 7:31am
#13
Hi Paul,
Thanks for the workout. A bit late but here is my solution:
Summary
Awesome work @scancela.90 Thank you for participating
@tweinzapfel I love it. I like the variation in colors and just limiting it to 5. Great job
Really great work @AlexisOlson
Keep going @Eze Good job!
Hakeem
April 11, 2023, 3:16pm
#20
Top N Highlighted Sales =
var selectedVal = 'Number of Highlighted Products'[Number of Highlighted Products Value] -- selected number
var topProducts = TOPN(selectedVal, ALL(Products), [Total Sales], DESC) -- list of top products
var totalSales = CALCULATE([Total Sales],
KEEPFILTERS(topProducts)
var result = IF(
totalSales = [Total Sales],
"#3eb489")
return
result
Bottom N Highlighted Cost =
var bottomProducts = TOPN(selectedVal, ALL(Products), [Total Costs], ASC) -- list of bottom products
var totalCost = CALCULATE([Total Costs],
KEEPFILTERS(bottomProducts)
var result = IF(
totalCost = [Total Costs],
"orange")
return
result
