Dax Top N Bottom N Modification
Hello EDNA Forum
I hope this email find you well.
What I’m trying to accomplish
Per the PBIX attached, how can I modify the Dax measure to only provide the Top 10 products and only the Top 10 customer for each product?
For Example*
When I select a number in the RankDisplay currently selected - 10 I only want to see the Top 10 Customers for the Top 10 products and the same for the Bottom 10.
Thank you in advance for your help!
Regards,
Dax Measure Example 03 18 21 TNBN_PCN.pbix (2.2 MB)
Hi @ambidextrousmentally! We noticed that your inquiry was left unsolved for quite some time now. We strive to answer ALL inquiries in the forum.
However, if you are sure that you provided all pertinent context to your concerns and read how to use the forum more effectively and still find your question unanswered, you can check out tutorials to learn this yourself as your membership also comes with relevant resources that may help you with your Power BI education.
