I have around 10 Conditional columns and I’m using them in 10 different matrix.
Is there a way to sort all those columns as I require.
I’m aware that I can assign a rank to them in the query editor and then sort them in visuals. But, can I do multi sort or something to have a custom sort for all the 10 columns?
Hi @kkrj.ankit, in Data View, create a column you can use as a sort key, then highlight the other column you want to custom sort, then on Column tools > Sort by column.
Thanks for your reply. But as I mentioned I have 10 conditional columns and all of them are unique and are not inter-related so would this work on all the columns?
I doubt that but still will check on it.
Hi @kkrj.ankit. Would it be possible for you to post a sample PBIX and a screenshot of your desired output? It will make pursuit of your issue easier. Thanks, Greg
** Then just sort your Risk Bucket & Turnover Bucket Columns by the associated Sort Column. So if you have 10 so called buckets, just create 10 Sort Columns to sort each by. Then you can just go in and hide the sort order columns in report view**
