I am trying to build a P&L Report but my data table does not contain a column that identifies the entries in each P&L Category. How can create a column that converts the GL Code to it’s appropriate GL Category NameFINANCE DATASET SMALL VERSION.pbix (3.2 MB) :
The ever-versatile SWITCH( TRUE() ) construct works great here. Just be sure first to change your Account Code field from text to whole number in Power Query.
Here’s the DAX for a calculated column to do the translation from code to category name:
Hi @jmolina, we’ve noticed that no response has been received from you within the last 24 hrs. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
