Current and Prior Period Measures
Having difficulty also creating formulas to create singular measures for:
• Current Month Loan Originations
• Prior Month Loan Originations
• Current Quarter Loan Originations
• Prior Quarter Loan Originations
• Current Year Loan Originations
• Prior Year Loan Originations
I’d like to show each measure as a card in my dashboards without creating calculated columns which flag if the month is current or prior.
Has anyone done this by chance?
Thank You,
Nick
Here’s a few formulas around this. You’ll have to sub in the correct ‘Loan Originations’ measure
None of the below formula require any calculated columns and are really suited just for cards, nothing else really
Current Month Sales =
VAR CurrentMonth = MONTH( TODAY() )
VAR CurrentYear = YEAR( TODAY() )
CALCULATE( [Total Sales],
    FILTER( ALL( Dates ),
        Dates[MonthOfYear] = CurrentMonth && Dates[Year] = CurrentYear ) )
Prior Month Sales =
        IF( CurrentMonth = 1,
        Dates[MonthOfYear] = 12 && Dates[Year] = CurrentYear - 1,
        Dates[MonthOfYear] = CurrentMonth - 1 && Dates[Year] = CurrentYear ) ) )
Current Year Sales =
Prior Year Sales =
        Dates[Year] = CurrentYear - 1 ) )
Current Quarter Sales =
VAR CurrentQuarter = LOOKUPVALUE( Dates[QuarterOfYear], Dates[Date], TODAY() )
        Dates[Year] = CurrentYear && Dates[QuarterOfYear] = CurrentQuarter ) )
Prior Quarter Sales =
        IF( CurrentQuarter = 1,
        Dates[Year] = CurrentYear - 1 && Dates[QuarterOfYear] = 4,
        Dates[Year] = CurrentYear && Dates[QuarterOfYear] = CurrentQuarter ) ) )
This should do it for all those.
Brilliant!! Thank you!!
Seems that perhaps the Prior Quarter calculation is off. It’s not clear to me how to fix it. Would you happen to know why it’s off? It appears to be returning far less than it should.
Hard to really say because I can’t see the values.
What is the difference?
Also have you tried breaking out each part of the formula. Just double check the CurrentQuarter is evaluating correctly for every row.
Instead of the LOOKUPVALUE for current quarter
Try this as the variable formula instead
SELECTEDVALUE( Dates[QuarterOfYear] )
Prior Quarter using LOOKUPVALUE produces less than Prior Month. Prior Quarter and Current Quarter return the same value using the same function. If I sub in the SELECTEDVALUE function, then the result is null.
Thank You,
Nick
Sorry I got confused. The original formula is correct, there was no need to change it.
It look like all you need to do actually is adjust the below
        Dates[Year] = CurrentYear && Dates[QuarterOfYear] = CurrentQuarter - 1 ) ) )
Just make sure to add the minus 1 to the end of the formula.
