Cumulative total for Difference measure
i have requirement
I have created currentmonthvalue on one facttable and previousmonthvalue on another facttable(this facttable is replicate of first facttable) and then i took difference amount measure.
MaterialClassificationslice
Excess
Old
New
Upon selection of above slicer for betwen 2 periods below table values are displayed
Now i need to get cumulative % for below table values.
Matid CuroMth Curtmonthval prevmonth prevmonval Diff Cumuative%
1 Jan2020 100 Dec2019 50 50 value
2 jan2020 150 Nov2019 70 80 value
Kindly help me on this
any reason why you created the 2nd fact table? Did you consider calculating previous month sale using
CALCULATE(SUM(InternetSales_USD[SalesAmount_USD]), PREVIOUSMONTH('Date'[Date]))
You can calculate cumulative sales using something like this
Cumulative Current Month Sales:=
CALCULATE (
    FILTER (
        ALL ( 'Date'[Date] ),
        'Date'[Date] <= MAX ( 'Date'[Date] )
the diff cumulative % then could be a simple Divide function
would it be possible for you to share your data model or a pbix file if the above information does not work for you?
thank you
two fact tables i am using because i have only one monthid column i am using for currentmonth and comparemonth comparisons.
So Facttable1 has
monthid value classification materialid
1 100 new 1
2 50 old 1
simlilartly another fact tabe has same vaues to find out comparemonth slicer.
I have two measures
SelectmonthValue = sum(facttable[value])
Comparemonthbalue = SUMX(FILTER(facttable2,
and(facttable2[monthid]=previousdatemonthanalysis,facttabl2[materiaid]=currmateirla])),facttable2[value])
previousdatemonthanalysis = selectedvalue[dimdate2[monthid]
currmateirla = slectedvalue[fact1[materialid]
so then i calculated diff from above 2 measure
diff = SelectmonthValue -Comparemonthbalue
now based on diff cumulative totlas has to calculate for each clasiificaion selcted in slicer
kindly do needful
can you please attach a pbix file?
Thanks for posting your question @amruthdna2018. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Newtesting_11MayWithdimdateCalendar.pbix (154.2 KB)
NewDataSet.xlsx (11.9 KB)
I am not able to find cumulative totals for Diff Column kindly do needful
I have shared my pbix and sample dataset did you get any idea on implmentation part
i have tried to get you started. You definitely do not need 2 fact tables. .so i deleted one of them.
In your fact table you do not have dates. so based on your month index i tried to arrive at the trandate using the date function.,
i set up the CalendardDate as your Date table. You absolutely need a Date table for what you are trying to achieve.
I set up the DAX code to help you calculate running total.
I am attaching the pbix file that i worked on. Pls review and build on it . let me know if you have any further question.
Newtesting_11MayWithdimdateCalendar.pbix (113.8 KB)
hi thanks for quick reply.
When i add material name to the table cumulative totals are not workng as expected
like 2 materials 2 rows same Trandateā€¦cumulative totals are not working
kindly help me on this
pls send your latest pbix
Newtesting_11MayWithdimdateCalendar_Updated.pbix (114.6 KB)
Please find attacheed pbix
