Cumulative PY differences
I calculated Cumulative Sales and Cumulative Sales PY in 2 different ways, one called Revenue (worked fine) the other one called Sales (not working as expected for PY only).
Cumulative Revenue =
CALCULATE( [Revenue],
FILTER( ALLSELECTED( ‘Calendar’ ),
‘Calendar’[Date] <= MAX( ‘Calendar’[Date] ) ))
Sales PY =
[Revenue], DATEADD(‘Calendar’[Date],-1,YEAR))
Cumulative Revenue PY =
CALCULATE( [Sales PY],
Cumulative Sales =
VAR LastSalesDate = CALCULATE( MAX( ‘Calendar’[Date] ), ALL( ‘Calendar’) )
IF( SELECTEDVALUE( ‘Calendar’[Date] ) > LastSalesDate, BLANK(),
FILTER( ALLSELECTED( ‘Calendar’[Date] ),
‘Calendar’[Date] <= MAX( ‘Calendar’[Date] ))))
Cumulative Sales PY =
[Cumulative Sales],
SAMEPERIODLASTYEAR(‘Calendar’[Date])
Moreover I which one should I always use over the other from a simplicity and performance standpoint.
Thanks a lot
It depends on exactly what you require.
The first ones are fine and would be simple best practice. The 3rd formula also looks fine if you want that logic.
The last one isn’t recommended. You want to use the top examples instead.
Thanks a lot, will bear that in mind going forward. This was me testing different code to get the same result whereby SAMEPERIODLASTYEAR didn’t do the job.
